How to replace a circuit breaker in your electrical panel. Is your breaker bad? Why is it tripping? You could have a bad, failing or defective circuit breaker. Your breaker can trip for many reasons but replacing the breaker can be cheap & easy and can let you narrow down what is causing you needing to reset your breaker intermittently or all the time.
Cheap volt meter: https://amzn.to/3lIYyQA
Volt detector pen: https://amzn.to/3ggLOQ8
Thrunite Flashlight: https://amzn.to/37B3cLn
This is to help you with your problem and point you in the right direction. YOU are responsible for what you do and determining what you are capable and feel safe doing.
I hope this video is helpful and may solve your problem and help you.
Disclaimer:
Due to factors beyond the control of Silver Cymbal, I cannot guarantee against improper use or unauthorized modifications of this information. Silver Cymbal assumes no liability for property damage or injury incurred as a result of any of the information contained in this video. Use this information at your own risk. Silver Cymbal recommends safe practices when working on machines and or with tools seen or implied in this video. Due to factors beyond the control of Silver Cymbal, no information contained in this video shall create any expressed or implied warranty or guarantee of any particular result. Any injury, damage, or loss that may result from improper use of these tools, equipment, or from the information contained in this video is the sole responsibility of the user and not Silver Cymbal.
Thanks for watching please LIKE & SUBSCRIBE – Volt meter: https://amzn.to/3lIYyQA – Volt detector pen: https://amzn.to/3ggLOQ8 – Thrunite Flashlight: https://amzn.to/37B3cLn
Just changed my fuse because of this video! Thank you!!
Now, turn the breaker on!
do you know what's compatible? my circuits jumped from 50 to 80 bucks. I did just buy my 2nd one b/c they keep dying. It's an eaton CHFAFGF120PN. Type ch, dual purpose caf/gf breaker. I don't know enough about breakers to know if there's a much cheaper one that could suffice in its place. I did change out the last one myself based on your vid, so that was awesome.
Worked exactly as shared. Took less than 5 min to actually do (after procrastinating for weeks for fear of killing myself). 🙏🏻
very nice video. thanks.
You are a wealth of information my friend. thank you for sharing!
Thank you sir
it is good to know what my handyman will be doing. Fortunately, i have a very affordable and knowledgeable person who seems to be a master of many trades. I am very lucky.
What if I replace a 15amp with a 20? Will it mess up anything?
? any problem with replacing a 15amp with a 20amp breaker? Need to put 2 frigs on the same outlet.
Excellent video dude. Explained in fine detail
Thank you so much for this video!
This was great & hopefully it solves my issue. The breaker doesn't trip all the way off & it will not click either way & the kitchen plugs along a certain wall doesn't work. I'm going to replace the breaker & see what happens. Thanks for the video.
If you don't already know like 95% of what's in this video, call an electrician
My sister called last night about a non-resetting branch ckt breaker. I am sure she can do this, but I want her to see it done correctly. Your video is JUST WHAT THE DOCTOR ORDERED (she IS a doctor! LOL). Thanks. She has internet through a battery powered JetPac and she has a battery-operated computer. I'm going to insist that she have the video cued up so she can watch step by step if she needs a memory booster.
Great job! Thank you!
Excellent video – thank you very much!
THANKS good job 👏 👍
I wish my husband knew how to do this job🤑🤑🤑🤑🤑🤑🤑
This was extremely helpful. I watched another video previous to this one that left me with many questions. Yours answered everything.
