Is your hvac unit ready for an upgrade? In this video I show how a company of one replaces a 4 ton heat pump split system as well as relocate the outdoor condensing unit to the side of the home. The existing heating and air conditioning unit had a faulty circuit board in the outdoor unit and a leaking indoor coil. This is how I replace a hvac split system. Hope you enjoy the video.
Video Rating: / 5
Time to replace your heating or cooling system? No problem! Learn how the team at Logan A/C & Heat Services can install a new furnace, air conditioner, heat pump, or air handler in your Dayton, Columbus, or Cincinnati, OH home now!
We are a local, family-owned, residential heating and air conditioning company that’s been offering repair, replacement, and routine maintenance since 1969. Logan Services has a long-standing accreditation with the BBB, which shows the commitment that we have to our customers and our services.
🔴 Subscribe to our Youtube channel: https://www.youtube.com/channel/UC4ORhk9-gYZ5XIo9fEoZJzQ?sub_confirmation=1
🔴 Recommended Videos:
About Logan Services: https://www.youtube.com/watch?v=0kgZzg-j6Gk
Our BBB Story: https://www.youtube.com/watch?v=uUwbx1D1oGs
Logan Services’ Company Values In Action: https://www.youtube.com/watch?v=ktw_XAtLRM8
🔴 Recommended Playlists:
Logan A/C & Heat Services – The Home Of Fast, Friendly Service: https://www.youtube.com/playlist?list=PLjqES-DeM7rPnNrM0Wd6WC-60v6n-8TIn
How To: https://www.youtube.com/playlist?list=PLjqES-DeM7rMnjixMHyh7_RQfSPKlGtck
Heating/Cooling Tips: https://www.youtube.com/playlist?list=PLjqES-DeM7rPdgCAE1uxpOB0-AWMn0foq
✅ Lets Connect
Facebook: http://facebook.com/LoganServices
Twitter: http://twitter.com/LoganServices
LinkedIn: https://www.linkedin.com/company/1506149
Pinterest: http://www.pinterest.com/loganservices
✅ Reach Out To Logan Services
Contact Us: https://logan-inc.com/contact-us
Book Your Appointment Online: https://logan-services-booking.com/yt
View Current Promotions: https://logan-inc.com/coupons
Get An Estimate: https://logan-inc.com/request-estimate
Schedule Service: https://logan-inc.com/request-service
#furnace #airconditioner #loganservices
✅ Learn More
Refer a Friend: https://logan-inc.com/refer-friend
Check Out Our Blog: https://logan-inc.com/blog-posts
Video Rating: / 5
The Work is CLEAN from Start to Finish. Excellent workmanship. That's how it's done brotha.
how do you remove moisture from they air.
It's amazing how most people do a "clean" installation when on camera:). I hope you do the same when not being filmed. Overall a very tidy installation. Personally I would had change the return to a rectangle duct so I can terminate on the handler below the filter. The round return you put in place comes partially above the air handler's filter. Also on the vacuum process, regardless if its a new system with a new lineset you need to purge it and make sure you do a decay test. Yes its all new but don't forget you opened the system to make the connections. Air and humidity is in your lineset and possibly oxidization if you didn't flow nitrogen during brazing (it wasn't clear on your video).
Despite all my picky comments its a NICE install and I wish there were more servicemen out there to do similar installs instead of "bothering" installs destined to fail the next season.
Im an installer for almost 2 years great install brother set the bar high!
Very clean instal
How are you legally able to run the power for these units? In Washington at k wet you need a class C electrical license to do stuff like that.
It's a work of art. Wow
A large portion of that return isn't even going throught the filter. He plays like he is doing perfect work but I don't even half to try to do this. He is nothing special.
First let me say I liked your video! I'm trying to do my homework before we get a new heat pump unit installed. Your video was the most informative.
I'm about to start an HVAC program I love watching this guy! I hope I can get this good one day. By the way I'm starting late I'm 30 😅. I was in the army for 7 years and figured this would be an awesome career so I wouldn't be stuck in a factory. And eventually work independently as you do 👍 anyway thanks man.
You rock. That was a great install video.
Well executed job!
Great work
Good jobs
Nice and clean, enjoyed!
Good job
Great video. My 2013 American standard compressor went out. My thinking is to have the whole outside unit replaced not just the compressor. We only purchased the house 90 days ago. It passed inspection just fine. I just wanted to see the process. You are very talented.
how much does something like that cost ?
"CLEAN INSTALL" (except for the inside of your (very nice) piping." cmon man! I guess that's why you have 2 driers lololol.
Can you keep the old unit
